This discussion topic has been answered Discussion topic: Full fibre network identified by smart tv . I seem to connect ok but when I then try to access error
Message posted on 31 Dec 2024 03:09 PM
I have had full fibre installation today . Engineer said external wall of property was best location. I have linked mobile phones ,iPad , Google nest wirelessly . However when following instructions to link LG smart tv , it identifies new network. I set it up wirelessly and it says it's connected .  But when I try to access anything requiring internet it says there is a problem with the internet connection and takes me to settings , sky router , wps button (does it have one) and hangs there.
Is it just impossible to link  to full fibre router wirelessly?
Message posted on 31 Dec 2024 04:04 PM
The WPS button is low down on the right hand side of the enclosure.
Message posted on 31 Dec 2024 03:41 PM
							Re: Full fibre network identified by smart tv . I seem to connect ok but when I then try to access e
With a white Max Hub you may need to reduce the wireless security level from WPA3-T to WPA2-PSK using the Hub settings in the My Sky app.
