Discussion topic: Full fibre installation. Will I be without internet for a long period
This message was authored by: Ah08
Good afternoon
im due to have my new sky full fibre internet installed by open reach on Wednesday? Will I be without internet while this process is happening or just while the switch over takes place?
many thanks Adam
Re: Full fibre installation. Will I be without internet for a long period
@Ah08 Smooth and working transition and if Engineer is doing it for you, then it's a five minute swapover! FTTP goes up and live, fttc falls away, landline phones may just take that little bit longer 24-4hrs to fully transition from the copper to the Fibre!
Any hiccups in the process, then who knows, new Fibre ONT, Power and Pon full green light, if you dont see that first then would not be swapping over!
Are you sky to sky upgrade copper fttc to FF Full Fibre install, OR openreach or CF CityFibre if you know!
