2
Discussion topic: Full fibre install
This message was authored by Charll482 This message was authored by: Charll482
Full fibre install
Just booked to upgrade broadband to ultrafast, engineer booked for the 17th. Agent on the phone didn't sound overly confident when I asked about the install process. We have a hard wired connection to a PS5 at the moment with having the ONT fitted, will this affect our existing ethernet cable does anyone know ?
This message was authored by GD1 This message was authored by: GD1 Answer
Re: Full fibre install
@Charll482  Your existing ethernet cable will connect to the hub, the Hub will connect to the ONT, it won't affect your ethernet setup at all.
This message was authored by mormegil This message was authored by: mormegil
It depends where you and the engineer agree to have the ont fitted
depending on where this is you may need a longer Ethernet cable but you want know until that happens
