Discussion topic: From amazing to poor signal since fitting today.
Message posted on 10 Nov 2025 07:17 PM
Message posted on 10 Nov 2025 09:16 PM
Re: From amazing to poor signal since fitting today.
@James-Lithers Are you checking all wireless speed testing or is there any wired Ethernet devices connected. On a FF900 connection from sky the hub should return on a device capable off doing so 900/110Mb/s from the OR connected fibre ONT.
First say if you know, OR Openreach or CF CityFibre connected with the ONT, helps give a fighting chance to assist you.
Looks like you have got the White sky Max hub for your connection to the ONT as you mention max in your opening!
Speeds can go up and down and network is shared so all devices want a slice off the cake, can be hard unless all off and only one connected to get the true picture!
