Discussion topic: Force a device to connect to 2.4Ghz wifi only
This message was authored by: blasteranster
Is it possible to force a device to connect to the 2.4Ghz wifi channel without giving the 2.4 and 5Ghz channels different SSID names? Worcester Bosch Wave thermostat loses connection when running dual band.
Re: Force a device to connect to 2.4Ghz wifi only
@blasteranster
For the black sky hubs read below on seperating the wifi into 2 ssids.  For the white sky max toggle on down to temporarily disable 5ghz
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
Avatar for blasteranster
Level 4 icon
I already stated I don't want to split the channels
@blasteranster
What colour hub do you have
You can just temporarily disable 5ghz on the black sky hubs as well.
Level 4 icon
That doesn't work as when the thermostat loses connection either from Worcester Bosch issues which they have a lot or a power cut it doesn't re connect after turning the 5ghz back on. Not much good if away from home and you need to use the app. It is a black sr203 hub
This message was authored by: FLC
@blasteranster
The only realistic option would be to add a wireless extender of your choice with a separate SSID running 2.4GHz only.
Level 4 icon
You mean 2.4ghz only lol
That's exactly what I said?
Well it does now! 😉
