Discussion topic: Flashing orange lights
This message was authored by No+internet11 This message was authored by: No+internet11
Why can’t I speak to anyone within sky without costing me money? I’m already paying for the broadband that doesn't work. Can someone please help get it working. There are four lights. The 2nd and 4th random old start flashing orange for 5 minutes and we loose internet then suddenly they're good again. It happens about 5 times an hour making the internet unusable. I've done all the tests and they say there's no problem
Re: Flashing orange lights
@No+internet11
Are you able to post your hub stats while the internet is up
Also if you run tests from your my sky app using 4g/5g data if it picks up an external fault it should let you book an engineer
No+internet11
I've done the tests while the lights are orange and it says it can't connect to the hum then says need more help and takes me right back to the useless forum. No way to contact a sky employee
@No+internet11  Looks like you'll need to call Sky.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
