Discussion topic: Firestick 4k max on sky broadband
This message was authored by: DatM
Does a firestick 4k max eotk when on sky broadband.....it mentions 6e on its description 🤷🏽‍♂️
Re: Firestick 4k max on sky broadband
@DatM the WiFi spec on devices lists the highest standard the unit supports but if you read the full specs it supports all wifi standards back to 802.11 B. The joke is the support for WiFi 6e speeds is totally pointless as the fastest WiFi speed anf streaming stick requires is around 50Mb/s given the unit is limited to 2160p at 60Hz.
