4
This discussion topic has been answered Discussion topic: Fibre install going bad to worse
This message was authored by: KirstyReader
I was not told at any time that I would need to have overhead wires to my property for the installation of Sky Fibre!!!!
we have been let down 3 times now with no one turning up and we are now waiting and we cannot get hold of anyone to talk this through and stop the overhead wires!!! We have been totally mislead!
Moderator notes: edited title
Re: Fibre I stalk stink going bad to worse
@KirstyReader
As @Sharcuk indicates, neither Sky or any other Openreach ISP get any say in how Openreach are deploying the national FTTP rollout in your area.
@KirstyReader you've posted in the forum for issues with the Sky Yahoo Mail service. You're not emailing Sky.
If you believe you have grounds for complaint, by all means give Sky a call.
Avatar for KirstyReader
Apologies in my haste I mistyped the Heading din't mean to put stalk or stink but can't change it SORRY
This message was authored by: Sharcuk
@KirstyReader The route taken to bring broadband to the outside of your property is not determined by Sky, or any other ISP if you are tempted to consider trying a different provider.
In most circumstances Openreach (or in some limited cases, City Fibre) provide the network infrastructure to the outside of your property, and it'll be their decision as to whether overhead wires are the only option.
The one exception is if you are in an area where either Virgin Media or a newer Altnet broadband provider have laid their own underground cable infrastructure in your area.
If your service hasn't yet been started you may be able to cancel without penalty by contacting Sky. However you will, unfortunately, have to do your own research to see whether an alternative provider is available in your area who are in a position to use their own underground infrastructure.
Failing this, there is also the possibility of other wireless broadband options, such as satellite or 4g/5g, but again you'll need to research availability.
Sky Q, 3 mini boxes, booster and full fibre gigafast. Good WiFi coverage throughout a 4-bedroom house!
@KirstyReader
