Discussion topic: Fibre fitted and now unable to connect sky glass via wifi or cable. connected to phones ok just is
This message was authored by: Andrew+Robson
Message posted on 24 Oct 2025 10:54 AM
Just had fibre fitted and now can't connect sky glass via wifi or via ethernet cable ( no network error). Phones in house all connected ok to wifi ?
Message posted on 24 Oct 2025 11:39 AM
Re: Fibre fitted and now unable to connect sky glass via wifi or cable. connected to phones ok jus
@Andrew+Robson Have no idea about sky Glass, wi-fi can be an issue for reconnecting especially if a new sky Hub, but cable not so sure. Would wipe out or reset the network if yhat is an option on a sky TV and go from there, cable will always be a better connection if you can do that!
