Fibre connection dropping... Any thoughts?
Executive Producer
Post 76 of 117
Re: Fibre connection dropping... Any thoughts?
@jamesn123
The downstream synchronisation speed has gone up I'd put that down to DLM and not take much notice of the BQM currently. What's the latency like using a latency (ping) test to the bbc.co.cuk?
Camera Assistant
Post 77 of 117
@mae-3
The downstream sync speed would always fluctuate between about 74mbps and 78mbps upon each sync, even with the old router, so I'd doubt it was DLM probably just a coincidence it re-sycned about 800Kbps higher.
Ping seems pretty inconsistent too
Pinging bbc.co.uk [151.101.192.81] with 32 bytes of data:
Reply from 151.101.192.81: bytes=32 time=13ms TTL=59
Reply from 151.101.192.81: bytes=32 time=11ms TTL=59
Reply from 151.101.192.81: bytes=32 time=15ms TTL=59
Reply from 151.101.192.81: bytes=32 time=12ms TTL=59
Reply from 151.101.192.81: bytes=32 time=16ms TTL=59
Reply from 151.101.192.81: bytes=32 time=14ms TTL=59
Executive Producer
Post 78 of 117
@jamesn123
What is the weather like at your location for it's raining here and quite windy? And does the telephone cable go overhead, if it does go overhead and weather is poor that may account for that high jitter?
Camera Assistant
Post 79 of 117
@mae-3
Very windy and rainy here, however on our street all cables are underground. Although on the main road towards the cabinet & exchange all cables are overhead, I am not sure if our cables go there or go underground all the way to the exchange. I would think they go underground all the way.
Executive Producer
Post 80 of 117
@jamesn123
Keep a note of the weather and an eye on the latency of the connection if it stabilises when the wind is low then that's is the answer on whether those cables go overhead near the cabinet.
Camera Assistant
Post 81 of 117
@mae-3
Connection dropped again and downstream speed dropped too
Also noticed massive fluctuation in the noise margin, it was down to 4.9db earlier before the connection dropped and now right up to 5.8
Router Statistics
System Up Time: 54:05:47
PortStatusTxPktsRxPktsCollision PktsTx b/sRx b/sUp Time
WANMER14402542807532064072148602400:56:21
LANUp48731879243310460935281629799254:05:47
WLAN (2.4 GHz)Disable0000000:00:00
WLAN (5 GHz)Disable0000000:00:00
Broadband LinkDownstreamUpstream
Connection Speed75031 kbps19999 kbps
Line Attenuation18.6 dB0.0 dB
Noise Margin5.8 dB7.7 dB
Camera Assistant
Post 82 of 117
Oh and weather is calm now and the ping tests are still spiking
Executive Producer
Post 83 of 117
@jamesn123
BQM or bbc.co.uk  latency test for only interested in the latter?
Camera Assistant
Post 84 of 117
@mae-3
bbc ping tests
Reply from 151.101.192.81: bytes=32 time=18ms TTL=59
Reply from 151.101.192.81: bytes=32 time=20ms TTL=59
Camera Assistant
Post 85 of 117
Connection dropped again this morning and if you look at the packet loss on the BQM I think the extent of the problem is pretty obvious
Router Statistics
System Up Time: 69:00:58
WANMER60637914346590366162222903:16:28
LANUp6458664131112348011372137324469:00:58
Connection Speed78327 kbps19999 kbps
Line Attenuation18.5 dB0.0 dB
Noise Margin5.4 dB7.7 dB
Executive Producer
Post 86 of 117
@jamesn123
There is clearly a fault and this needs to be addressed by Sky. Smiley Sad
Camera Assistant
Post 87 of 117
As i expected Smiley Sad
Camera Assistant
Post 88 of 117
@mae-3
Sky are still claiming that the line has not gone down for a while. Do you know what could be making it so they cannot see line drops?
Executive Producer
Post 89 of 117
@jamesn123
The DSLAM in the cabinet must be faulty if they cannot see the line drops.
Camera Assistant
Post 90 of 117
@mae-3
Hmm possibly but the thing is they can see a line drop if the router is rebooted but cant see a line drop if the line is just dropped
Recommended Threads
28-05-2018 12:38 PM
11-06-2018 02:59 PM
21-03-2018 12:04 PM
08-03-2018 08:14 PM
13-04-2018 08:19 PM
