13 Feb 2024 01:26 PM
Hi, fibre has just arrived in my area. I'm going to be able o receive minimum speeds of 500mbps.
I'm tempted as a sky customer to add broadband to my package, but Eir sales ( my current broadband provider) has said that Eir Fibre Broadband will be faster than Sky Broadband!
I was under the impression that speeds from all suppliers would be the same across the board under the NBI network??
Looking for advice please?
13 Feb 2024 01:41 PM
Posted by a Superuser, not a Sky employee. Find out moreThe speeds should be the same, not sure what actual reason EIR could give that would make their speed faster than Sky.
13 Feb 2024 02:40 PM
If regulation in the Republic is the same as the UK (and I suspect it's very similar) then EIR as an ISP has exactly the same access to the wholesale bandwidth market as Sky.
ISPs can choose to supply broadband with, for example, a lower contention ratio, but they generally don't on domestic broadband because it would make their customer-facing prices uncompetitive.
14 Feb 2024 08:31 AM
Have you tried the availibility checker?
https://www.sky.com/broadband/buy?irct=fttp-hero-prospect
That should tell you what they can offer.
