Discussion topic: Failing to reach minimum downlad speeds
This message was authored by MrsLG12 This message was authored by: MrsLG12
Hi There
Minimum speed is meant to be 50mbps but been getting 33/34mbps for a while now.  How can I get this fixed?
Re: Failing to reach minimum downlad speeds
@MrsLG12
Can you post your hub stats
MrsLG12
Router Statistics
System Up Time: 71:21:18
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 15247021 30471429 0 26000 1490895 71:19:26 LAN Up 322298 245699 0 3232 21183 71:21:18 WLAN (2.4 GHz) Up 20959695 10165144 0 2405459 39775 71:19:41 WLAN (5 GHz) Up 10116279 4262677 0 0 114 71:19:39
Broadband Link Downstream Upstream Connection Speed 34022 kbps 3149 kbps Line Attenuation D1(18.8 dB) , D2(34.3 dB) , D3(46.4 dB) U0(21.2 dB) , U1(28.8 dB) , U2(40.5 dB) Noise Margin 3.1 dB 5.8 dB
Poll Interval:
Seconds (at least 3s):
@MrsLG12
And can you run tests from your my sky app and post the info in more about your connection to see your minimum guaranteed download speed
MrsLG12
Its tells me everything is working fine but my speed is 34mbps, it doesnt change if I use my app or a desktop PC
This message was authored by TechmanagerMal This message was authored by: TechmanagerMal
  • Run this test - Broadband check | Sky.com
  • On the more about your connection link it will show your minimum download speed, can you post that?
Passing on the tips I have learned in over 24 years as a more than satisfied Sky customer.
@MrsLG12
Thats why i would like to see the info in "more about your connection" after you run the test. At the minute your stats don't really show anything untoward. Your noise margin at just over 3db is as good as you'll get
MrsLG12
As I said at the start minimun is meant to be 50mbps
@MrsLG12
We would like to see what it says now. Guarantees can change due to line conditions etc that are not viable to repair
MrsLG12
@MrsLG12
Thankyou. I just read it. There is definately a fault but the hub stats don't show were
This message was authored by daveNOS This message was authored by: daveNOS
@MrsLG12 The router stats suggest that 50mbps isn't achievable on your line, there is little the forum users can suggest other than call Sky and see what they say as it doesn't appear that you have a fault.
@daveNOS there defo something wrong. Noise margins fine but line attenuations a bit high for a 50Mbps guarantee. Scratching my head
@MrsLG12
You could call sky on 150 from a sky landline or
zero three three three seven five nine one zero one eight from any other phone
Or if in Ireland
Call sky ireland on
08.185.00.27.2
Remove all the full stops
Or we can escalate
MrsLG12
Thank you, helpful answer, will call them
@MrsLG12
Let us know how you get on and any diffs get back to us
