3
This discussion topic has been answered Discussion topic: Factory Reset Sky Max Hub, now does not show in MySky app
This message was authored by: Noopy66
I am having trouble setting up Port Forwarding, and one suggestion I read was to reset the hub and reinstall the MySky app, however I have factory reset the hub today and now when I go into MySky app and Product Settings the Sky Max hub is no longer showing so I cannot go into the options I need to use via the app.
I have tried the various reset options in trouble shooting, like reset the gateway, then reset Wi Fi and Router modules etc, no difference
Any suggestions to fix this?
Re: Factory Reset Sky Max Hub, now does not show in MySky app
@Noopy66 there is an issue with the app showing the Sky Max details which us under investigation which is likely to be the cause of your issue
Avatar for Noopy66
Level 2 icon
@Chrisee - many thanks, was working OK yesterday, I will wait a while and see when it get fixed
@Noopy66
It only occured this morning
I am NOT a Sky Employee
