Discussion topic: FTTP gigafast upload speeds
This message was authored by casperuk76 This message was authored by: casperuk76
After moving to gigafast a few months back upload speeds have stayed at 20mb/s. I know it's an average of 90mb/s but is there a minimum? Done all the ONT reboots etc
Re: FTTP gigafast upload speeds
@casperuk76
Sky have had issues with the gigafast package which is why its had stop sell put on it for now but ideally you should still be able to get the speeds.
Are you testing with a device connected via ethernet?
I am NOT a Sky Employee
casperuk76
Yes Cat6A ethernet with 1000FDX hard set.
@casperuk76
Did you try switching your Sky hub off for 30mins as this will fetch you a new public IP which may also modify your route through Skys servers and fix the low throughput.
casperuk76
Yes have tried many switch offs and reboots. Have changed just this week from 92.x.x.x to a 5.x x x
@casperuk76
Are you getting the full download speed? If so it does suggest a problem.
If you are not getting the full download speed either then it may be a capacity issue which is the suspected reason Sky stopped selling Gigafast for now
casperuk76
Yes getting at least 700mb/s down sometimes more
@casperuk76
I'll flag your post to Sky, look out for an email or message on the forum from an agent.
Best thing you can do is just say your getting low upload speeds, they may say its not guaranteed which technically is correct but 20mbps is exceptionally low for Gigafast
This message was authored by Tom-W19 This message was authored by: Tom-W19
Posted by a Sky employee
Thanks for escalating. We've sent an invite to casperuk76.
Tom
This message was authored by Kenny+Rankin This message was authored by: Kenny+Rankin
Hi - can you provide further details on the Gigafast issues Sky are having ?
I have Gigafast but am keen to understand why Sky withdrew availability
—————————————————————————————————-Sky Stream, Sky Gigafast Broadband with SR203 Hub
They stated that network upgrades were required and put a temporary stop sell on it
@Kenny+Rankin
A Sky Broadband spokesperson said:
“Providing a fast and reliable service is our number one priority. We are currently optimising our network and have temporarily paused new sales of Sky Broadband Gigafast while we do this. Existing Sky Broadband Gigafast customers are not impacted.”
https://www.ispreview.co.uk/index.php/2022/11/sky-broadband-uk-remove-900mbps-gigafast-fttp-plan-fro...
casperuk76
So I have had to put the sky hub back in place, for them to able check the router logs, but as they don't guarantee upload speeds (not sure why not on FTTP??) they are pretty much saying tough !
@casperuk76
That is unfortunately correct, Openreach dont guarantee upload speeds therefore no ISP using Openreach infrastructure guarantees it either.
