196
Discussion topic: FTTP: Voice light goes to orange and the internet stops working.
This message was authored by Grantero This message was authored by: Grantero
Re: On the new sky hub there is a solid orange light on voice part of the router display
You will get nowhere with sky...they will get you to restart your hub which fixes it temporarily and that's enough for them to close the case. Or they will send you a new hub which doesn't solve the problem either.
i spoke to someone who works at sky retentions and they say sky know their hubs don't work with the ultrafast plus but they don't care. I swapped my hub for a unbiquiti UniFi Express router and I have never had the problem since. It's a shame they don't care to fix the issue with their hardware.
This message was authored by Nat95 This message was authored by: Nat95
Restart didn't work.
He tried to run the test tool on his end and it wasn't doing it for him.
Thanks for the reply,  I'll get one of those routers ordered 👍  I've been with sky just over a month now so unfortunately can't back out without paying the big termination charge
This message was authored by Keefykeef37 This message was authored by: Keefykeef37
Re: FTTP: Voice light goes to orange and the internet stops working.
Any update on this? I've had the same issue ever since I joined fibre. Amber voice light knockoffs out Internet, have to reset about 3 times, sometimes even the fibrebox. Glad it not just me.. come on sky sort it.
This message was authored by rick+fowler This message was authored by: rick+fowler
Sky still couldn't fix the problem we still had no internet, tv on second box or landline service after 12 days. They admitted it's a server issue but still couldn't fix it even going past stage 3 escalations.
so we left Sky for tv, landline and internet, With no charges for being still in contact and compensation for the days without internet as they were in breach of contract for not providing the service paying for.
This message was authored by Robbo0410 This message was authored by: Robbo0410
@andy7262 they don't do nothing about it, they escalate it and give you a callback, and if it's been up a couple of days without any drops they close the case, your wasting your time, the channel keeps changing on mine from 36 to 44, pretty much halfing my bandwidth/speeds for any devices that are wireless the router they provide is absolutely useless once my contract is up in November I'll be looking elsewhere I hear Zen are pretty good for full fibre
100% the router mate, I'm not paying for a 3rd party router not when I'm already paying a small fortune a month for the broadband, you could try and cancel but I doubt that'll happen cause everything will be fine on there end
This message was authored by andy7262 This message was authored by: andy7262
(Removed) I've tried several new hubs  only one I havnt tried is the new hub 6 but it has Comcast software in it and won't connect to the existing boosters, (Removed)
Moderator note: Removed inappropriate details
Andy
I was looking at Zen, very good on trustpilot there router is WiFi 6 also, so it'll be a better router altogether then Sky's and probably isn't limited to 2 channels on the 5ghz band, I'll see how I feel come November
This message was authored by J1m+B This message was authored by: J1m+B
Same problem - response from Sky "...there is nothing more I an do as our tests show there is nothing wrong with your broadband connection"
Absolute joke isnt it they are well aware of the issue
Andy
@andy7262 best advice is to power down the Sky hub for 60 minutes as thst should switch you from the dodgy port on the server which is connecting your service.
There are well over 100 of these servers around tge country and they handle many millions of customers at any one time so where faults do occur which take time to be fixed.
This message was authored by earnhardt This message was authored by: earnhardt
Was it this one ?https://www.broadbandbuyer.com/search/?q=ubiquiti+unifi+express
Was it easy to do ? Cheers
This message was authored by 1NickAJ This message was authored by: 1NickAJ
I gave up and bought a new Asus router. Was fed up of random items on the network being unavailable, and the annoying orange light issue.
As far as I know it hasn't dropped out since then and I've got WiFi 6 connection to mobile phone and laptop.  I'd already moved my landline to VOIP so didn't need the phone option.
So your not using the sky router VoIP option ?
No, ported my number to Andrews and Arnold, £1.20 per month line rental. Already had a VOIP enabled phone plus I also get calls on my mobile using Linphone app.
No worries then if / when I change internet provider.
