Discussion topic: FTTP: Voice light goes to orange and the internet stops working.
Message posted on 17 Jan 2024 09:02 PM - last edited: 17 Jan 2024 09:04 PM
Re: On the new sky hub there is a solid orange light on voice part of the router display
Had to take screenshots as it wouldn't let me copy and paste the log in and put it in here, I've basically powered down the router then powered it back up, it solves the problem but it's only a temporary fix, it had also done it earlier around 7pm and all there was in the log was lease renewal unsuccessful once every minute, something on Sky's end that they can't seem to fix unfortunately
Message posted on 22 Jan 2024 11:10 PM
I have been having this problem ever since I got sky fiber to my property last year I've had 2 new hubs and a third has been sent out. I've had two Openreach engineers out but as the problem is fixed by simply restarting the hub or ONT sky don't care to look any further as to them the problem is "fixed" it's honestly a joke at this point.
Message posted on 06 Feb 2024 08:29 AM
Re: Sky hub equipment not working
Hi there @apopo, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 08 Feb 2024 08:30 AM
We are still looking to help you @apopo. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Message posted on 12 Feb 2024 04:13 PM
Voice light on Amber knocks out Wi-fi too
Message posted on 12 Feb 2024 06:40 PM
Re: Voice light on Amber knocks out Wi-fi too
@Col1972 Are any other lights on the router changing colour when this happens? Like the internet light going out and start flashing or does that also stay solid green when it happens?
Message posted on 12 Feb 2024 07:25 PM
@Highlinder no all the other lights remain green but for the voice light.
If I run a broadband check from the app it states there are no issues but there is as wi-fi drops out.
Message posted on 12 Feb 2024 08:03 PM
@Col1972 Do you have to re-start the router in order to get the Wi-Fi working again or does it just start working again after the voice light goes back to green?
Message posted on 14 Feb 2024 11:48 AM
@Highlinder I normally re boot as I work from home so rely on the wi fi. On occasions where it has gone back to green, can only think of 1 occasion, then it does work again.
Message posted on 14 Feb 2024 02:38 PM
@Col1972 Could you please post your router stats following the link below when this happens again before you re-boot the router if you are able to connect to it.
Message posted on 21 Feb 2024 09:01 AM
Broadband issues dropping constantly ! Amber voice light
We have had constant issues after installing alleged high speed connection. It drops out randomly and the Amber voice light is on. One engineer visit , new router checked everything . Felt it might be router as open reach can use recommissioned routers. Unfortunately not two attempts to make further appointments . Issues with making appointments by call handlers managed to make one myself which is now not showing as booked 🤦♀️ so wondered if anyone who had this broadband issue might have a solution that worked for them
Message posted on 22 Feb 2024 09:52 AM
Re: Broadband issues dropping constantly ! Amber voice light
Hi there, @Nina55. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 04 Mar 2024 12:04 AM
Connected with Internet?
Message posted on 04 Mar 2024 07:37 AM
Re: Connected with Internet?
@Cm1200 the lights on the hub tell you the status of the hub as explained here https://www.sky.com/help/articles/hub-lights-explained-start
The right hand light is for the voice service and on occasions you can have a green internet light and an amber voice light and not have an internet connection which happens because tge hub is connected to the exchnage line but a fault in the Sky server managing your connection is stopping traffic. Quickest way around this is to drop the connection for 30 minutes which often gets you onto a different unit.
Message posted on 06 Mar 2024 09:08 AM
I am having exactly the same issue since upgrading to Sky Fibre Ultrafast. Every now and then (typically once or twice a week) my Voice light goes amber and my connection goes down.
Every time it happens it is resolved by resetting the router. I've tried two routers and it still happens.
Don't Sky know they have a serious problem here?
