Discussion topic: Extend master socket or use extension?
This message was authored by Danstantheman This message was authored by: Danstantheman
Hi,
my new SKY Q router is currently plugged into the master BT Socket but it is situated in a secluded corner of an extension and as such my wifi is a tad slow.
There is an extension phone port which sits in a much more central and open area of my downstairs. Can I plug my broadband directly into this? This would actually allow me to connect ethernet to my to box which I would prefer!
If this is not suitable would it be better to run a longer (5 metre) cable between the master socket and the router? If so...which cable?
Re: Extend master socket or use extension?
@DanstanthemanYou would be better if you could get a longer rj11 to rj11 cable so that you can move the router. It is better than trying to use an extension port within the property.
Danstantheman
Thanks @Highlinder . I know with audio cables there are better quality ones... is this the same with the rj11 cables!
@DanstanthemanI would shop around for one, but try keep the length down to what you need as the more you add the distance does increase.
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
@Danstantheman
As @Highlinder has mentioned, a longer RJ11 cable would be best. I have used a six meter one in the past without any issue to speed or connection.
I think I got mine from Amazon, wasn't expensive if I recall.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
This message was authored by Thea-Belle This message was authored by: Thea-Belle
Hi
On this topic; currently, my master socket and router is in the same small room as my TV, but is on the opposite wall and I want to move it so that all my media hardware is together. Although it is a very small distance between the two walls, I would need to run the cable over a door frame and around the skirting so that it's not just trailing across the room.
From what I've seen, I can use an RJ11 extension cable to connect the router to the master socket so that I can move it, and I think that 10metres will do it. Can someone confirm if this is all I need to do please?
Thanks very much in advance for any advice.
Danstantheman
That's exactly what I have done using a 10m cable and don't notice any difference.
@Thea-Belle wrote:
Hi
That should work without issue @Thea-Belle
