Discussion topic: Extend WiFi with Ethernet cable to an outbuilding 30metres from house
Message posted on 06 Dec 2024 09:14 AM
We have sky hub 4.2 in the house. We have run an Ethernet cable from the house hub into an outbuilding and are looking to plug that into something that will extend the WiFi . Has anybody and suggestions?
Message posted on 06 Dec 2024 09:26 AM
Re: Extend WiFi with Ethernet cable to an outbuilding 30metres from house
Either a dedicated wireless access point, a router running in a dedicated access point mode (not its default settings) or a Sky wireless booster.
Message posted on 06 Dec 2024 09:53 AM
Many thanks for your help. Will look at the router option. Just got to look online how to do it as not sure how to change it at the moment. Cheers
Message posted on 06 Dec 2024 10:23 AM
Typically a commercial third party router will have an access point mode selectable in its settings. ISP routers usually won't do so, and are best avoided for this role.
Message posted on 06 Dec 2024 01:59 PM
Many thanks for that clarification. Will def go down the commercial router option. Cheers
