Discussion topic: Everyone the electric drops my box goes on red light and I cannot re-set it. Why is that?
This message was authored by: EVO82
I have a red lighton my box, tried to re-set it and nothing works. This is not the first time time it happened. The service checker says all is good.
This message was authored by: Evo83
Red light on the router
Every time electric drops my light on the box goes red, I cannot re-set it after that. Is it a faulty box?
Re: Red light on the router
@Evo83 @EVO82
I suspect you are one and the same and have posted the same question under two different tag names so the posts have been merged together.
@EVO82 most hubs should automaticallt reconnect after a power outage when they have fully rebooted which takes up to 5 minutes. Routers are delicate pieces of equipment and can be damged by power surges around power cuts which could be the issue.
Given Sky's hubs are designed to run 24/7 this should be a rare occurance which if it is happening frequently isxwhy is the powercdropping?
