22 Mar 2024 02:25 PM
Every day my Broadband and Streaming TV cuts off. Sometimes 10 times a day. The Broadband modem lights are all green , then all go off, then the 4th light goes red. Slowly they all come back on but the red light stays on for a while. During this time the internet goes off and the Streaming TV blacks out. Even when the internet comes back on it takes ages for the TV to come back on.
I've moved the modem and even used ethernet cables to try and fix problem. When I check service in the area it says "No Problem"
Run out of ideas.
Help
22 Mar 2024 03:27 PM
Posted by a Superuser, not a Sky employee. Find out more@Frank1955 Could you please post your router stats following the link below.
22 Mar 2024 03:40 PM
Hi Highlander,
How do I do this?
26 Mar 2024 12:29 PM
Posted by a Superuser, not a Sky employee. Find out moreThe link that was provided has all the steps written out
07 May 2024 07:10 PM
This what happens nearly EVERY DAY.
syslog: [ 0.213000] brcmboard registered
syslog: [ 18.366000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link UP 100 mbps half duplex
syslog: [ 19.468000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 100 mbps full duplex
syslog: [ 21.415000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link DOWN.
syslog: [ 21.506000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
syslog: [ 23.478000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link UP 100 mbps half duplex
syslog: [ 23.567000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 100 mbps full duplex
syslog: [ 43.263000] Line 0: xDSL link down
syslog: [ 51.267000] Line 0: xDSL G.994 training
syslog: [ 54.267000] Line 0: xDSL link down
syslog: Voice Configured
syslog: Voice Initialized
syslog: Voice Connecting
syslog: [ 66.268000] Line 0: xDSL link down
syslog: [ 68.268000] Line 0: xDSL G.994 training
syslog: Voice Disconnected
syslog: [ 82.268000] Line 0: VDSL G.993 started
syslog: [ 94.269000] Line 0: VDSL G.993 channel analysis
syslog: [ 94.808000] Line 0: VDSL2 link up, Bearer 0, us=5908, ds=39999
syslog: [ 94.808000] Line 0: VDSL2 link up, Bearer 1, us=0, ds=0
syslog: sky dhcpc client (v0.0.1) started
syslog: WAN IPV6 UP
syslog: Voice IP Connection Up: 2a02:c7c:5863:e900::1/64
syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: [D21020BC001846/9C31C383EDE0//7.03.0704.R/2a02:c7c:5863:e900::1]
syslog: Send out NTP request to ntp1.isp.sky.com
syslog: TR69: Connect to Production ACS
syslog: ptm0.1 - WAN link UP.
syslog: Received valid DHCP lease from server. Connection UP.
syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: [D21020BC001846/9C31C383EDE0/2.126.167.195/7.03.0704.R/2a02:c7c:5863:e900::1]
syslog: Send out NTP request to ntp2.isp.sky.com
syslog: Time has been set from ntp2.isp.sky.com
syslog: Received NTP Sync Reply from ntp2.isp.sky.com
syslog: TR69: Connect to ACS Failed: Could not resolve host
syslog: TR69: Connection to ACS Complete
syslog: Voice Connected
syslog: TR69: Close ACS Connection
syslog: Voice DeInitialized
syslog: Administrator login successful from IP: 192.168.0.16 .
all day
09 May 2024 10:06 AM
Posted by a Superuser, not a Sky employee. Find out moreWe can see your line is dropping from the log but you didnt post your stats so I am not sure how much of a fault the line has. Either way you'll need to engage Sky support on this and tell them you have a unstable line.
09 May 2024 11:51 AM
Been having the same issue for 6 weeks....so far technical dept. have sent two new routers....made no difference. At one point I was asked to remove the network cable from router and ont and fit it the other way round!
The sky network engineers can see no fault so will not send an openreach engineer out. Spent 2 hours on phone to sky tech last night....they still say no issue that they can see....at the same time my speedtest is showing less than 1mb ( I have fibre100).
today I have solved the problem....cancelled sky, they allowed me to do this f.o.c, as I have 'speed issues on my line'..Virgin coming in a week to install their fibre.....and it's only £23.50 for 125mb. Result!
if you can't go through the problem, go round it!
