Discussion topic: Eufy hub won’t pick up cameras
This message was authored by: KJ832
Message posted on 13 Jan 2025 07:37 PM
I have changed to fibre and notice my eufy hub can connect but won't find cameras.i have removed the sync to 5ghz and so split the broadband.
still doesn't work - any ideas? Do I need to change security settings or something
Find out more
Message posted on 14 Jan 2025 11:00 AM
Re: Eufy hub won’t pick up cameras
Which Eufy cameras are you using? I am pretty sure most Eufy cameras connect directly to your Eufy Homebase, not to your WiFi hub.
I am NOT a Sky Employee
