Discussion topic: Error message your sky broadband isn’t showing any info
This message was authored by white-cross This message was authored by: white-cross
It's been like this for ever. Is it a fault or is this a normal situation?
Re: Error message your sky broadband isn’t showing any info
@white-cross where are you seeing this message? If your devices are connected I wouldn't worry.
white-cross
@Chrisee   On my Sky app
@white-cross it is likely you are not signing in on the Sky ID linked to thecaccount or the id is screwed if the latter call Skybto get it dorted butveithercway if the service is working I wouldnt worry too much.
