3
This discussion topic has been answered Discussion topic: Erase personal info on Sky router?
This message was authored by: PTFarnsworth
I want to return or recycle my Sky router/modem (ER110) as I have switched broadband providers. Does the router contain any personal information (aside from the now obsolete wifi password)? If so, how to erase?
This message was authored by: Laing1 Answer
Re: Erase personal info on Sky router?
@PTFarnsworth not sure what personal information the router would hold but if you are worried you should be able to reset the router to its factory settings, I can't remember if the ER110 has a button on the back or a pinhole to do this
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for PTFarnsworth
Thanks a lot, indeed there is a button, I will give it a push.
@PTFarnsworth  Hubs don't have any of your personal details stored, they simp,y don't have the anility to store anything like that, they are purely designed to allow access to the WWW via a gateway.
