Discussion topic: Ember light flashing on hub
This message was authored by: MAWAN
Heavy rain causing connection problems to the hub
Re: Ember light flashing on hub
@MAWAN
Heavy rain shouldn't usually cause broadband issues so if you have no working broadband then try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
