1
This discussion topic has been answered Discussion topic: Due to switch tomorrow, do they enable early or late usually
This message was authored by: SteveLP
I have some software that uses the internet and wondered if I should let it run or just leave it for the day if SKy usually do the switchover early in the day. It's an FTTP connection so guess just needs a switch thrown no engineer call or anything
This message was authored by: JimM1 Answer
Re: Due to switch tomorrow, do they enable early or late usually
@SteveLP If it is anything like mine EE to Sky, text was recieved at 3.00am you are switched over FF500 on both, was well and trully fast asleep and the EE router stayed up all that time, eventually about midday when the wife decided it was ok, the usual hope this just takes a couple off minutes she said, but yes, put the sky hub online, i had already set ssid, password, admin password, WANoE settings as very familuar with the SR203 as had one for about 4 years, it connected within a couple minutes, did it's FW update, re-booted and back up, left it all 48hrs just so it settled, took a quick web look at that time, 7.00am reset as my starting period and 1200hrs later still up nothing too weird, missed a wanoe drop, and the usual 5Ghz stat's screwball but fine zero problems. Retired it about month ago now and just got the Asus routers up front and centre. Hope yours goes just a smooth. 👍
