Discussion topic: Dreadful since Sky Superfast fibre upgrade
This message was authored by: Stephaust
We've had so many TV problems since upgrading to Sky superfast fibre
Re: Dreadful since Sky Superfast fibre upgrade
Is this related to the Sky Go service????
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
@Stephaust
What issues are you having ?
Avatar for Stephaust
Apps on Tv are often not working. Connection is often lost. Tv becomes fuzzy.
Yet My Sky says everything is fine.
This message was authored by: MichRig
Mine has been exactly the same, programmes keep freezing or stopping
This message was authored by: Shari28
Hi, also having issues since the upgrade. Tv programs stopping, have to exit to home and try again to watch show. Am occasionally getting messages from Sky that my speed is slow, and router needs checking
@Shari28 @Stephaust @MichRig switching to full fibre often means tge Sky hub has been moved or even be changed. Unfortunately this can affect tge WiFi signal levels in your home. Ideally try to move the hub to a better position which is ouut in the open on a surface so its above obstructions like radiators. You may find tge cable Sky provided to link tge hub to the ONT unit is too short but this is only a standard Ethernet cable which can easily be bought online or from most supermarkets in longer lengths.
Beyond tgat you may need a WiFi extender which Sky can supply if you buy their WiFi Max package. WiFi strngth is determined by the layout and type of cinstruction of your home so isnt something Sky can control unfortunately.
