Discussion topic: Dreadful download speed for over a month - Nottingham
This message was authored by: MCooper1967
Our internet service has been abysmal for around a month now. We work from home and it's becoming virtually unusable. The tests run say they know there is a problem and they need to send an engineer. I have done this twice, first time no follow up, second time apparently he came and fixed it! I had a text to say so, though no access to the house was needed. It's not improved one bit. My speeds have been been around 3. 2 on a daily basis and I pay for superfast - should be a minimum of 36!
These are my router stats - I have no idea what they mean. Am seriously thinking of going over to Starlink!
Router Statistics
System Up Time: 342:15:11
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 14361169 18592461 0 219276 3798265 14:44:43 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 5690511 154120 0 9436 0 342:13:16 WLAN (5 GHz) Up 204605224 135484627 0 0 0 342:13:10
Broadband Link Downstream Upstream Connection Speed 4200 kbps 3195 kbps Line Attenuation D1(14.3 dB) , D2(34.4 dB) , D3(54.5 dB) U0(1.3 dB) , U1(26.9 dB) , U2(42.4 dB) Noise Margin 18.1 dB 14.9 dB
Re: Dreadful download speed for over a month - Nottingham
Definitely something wrong there,: an FTTC connection should never be almost symmetrical in speed.
You'll need to persist with logging a fault for external investigation.
I'd note your Hub hasn't been rebooted for a long time, and that you're only using WiFi (which is likely to be losing additional speed)
