07 Feb 2023 05:59 PM
I have replaced the sky router with a Draytek Vigor 2865 which gives great performance, however the issue I have is the phone which connected to the Sky router, but will not work through the Draytek.
Anyone manage this? I have tried to connect directly to the phone socket, but still dead.
Thanks for advice.
07 Feb 2023 06:09 PM
Posted by a Superuser, not a Sky employee. Find out moreIf your telephone connects to the Sky hub this means you have VOIP calls therefore your phone will only work via the port on the back of the Sky hub. No 3rd party router will be able to acomplish this.
Your options are to abandon your landline phone or run the Sky hub as your primary router & connect a 3rd party one to the Sky hub as a secondary router/ap
08 Feb 2023 07:49 AM
Once the address is provisioned on SOGEA broadband there's no longer a PSTN phone signal (or exchange power) being delivered, so wall sockets won't work. This will be the case for the whole network by sometime in 2025.
