Discussion topic: Doorbell on 24.gbz
Message posted on 06 Jul 2025 07:28 PM
Doorbell on 24.gbz
I need to connect to 24.gbz for door bell please help
Message posted on 06 Jul 2025 07:49 PM
Re: Doorbell on 24.gbz
I suspect you mean 2.4Ghz
Do you have a black or a white Sky Hub?
Message posted on 06 Jul 2025 07:55 PM
A black one
Message posted on 06 Jul 2025 07:57 PM
I cant connect my door bell it wont work on 5gbz
Message posted on 06 Jul 2025 08:26 PM - last edited: 06 Jul 2025 08:58 PM
GHz, for 'gigahertz' (named after Heinrich Hertz, the 19th century German physicist who proved the existence of electromagnetic waves)
As posted by @jamesn123
Note that this process does not apply to the new (white) Max Hub
So to split the two channels you need to go to your router config page which can be found by typing 192.168.0.1 into your web browser.
To access the page, you'll need;
username: admin
password: your WiFi password
- Select wireless from the navigation bar and scroll down a little and untick the 'Synchronise 2.4GHz and 5GHz settings'
- Scroll to the bottom of the page and hit apply.
- Once the page reloads you need to go to the 5GHz wireless settings page on the sub navigation bar below where you click wireless before
- In the 5GHz section you want to go to the box called 'Name (SSID)' and add something like 5g to the end of the current name
- Scroll down and hit apply
- Then on any wireless device you should now see two networks. One network will be the same name as usual and will be 2.4GHz band and the other will be the usual name with 5G on the end (Or whatever you typed). Connect any 5GHz capable device to the 5GHz network and see if it works correctly. The WiFi password should be the same if you havent changed it.
Message posted on 06 Jul 2025 08:41 PM
Thank you for explaining but im no good at things like this..
Message posted on 06 Jul 2025 08:49 PM
@maryjayne What is the doorbell that you are trying to connect, the Ring range works fine on the 2.4Ghz band and connected to the SR203 Black sky Broadband hub! Mine is called the Video doorbell (2nd Gen) as the Ring app say's....
