Discussion topic: Doorbell device loses WiFi connection
This message was authored by: M4R5H
We've had a ring doorbell for 10 months and has worked perfectly fine until 3/4 weeks ago when it disconnects daily from the WiFi. I then have to manually reset it so that it works. I've even had a replacement device as we thought that may be the issue. I've also changed the settings on my sky q box as read that the downtime at night could disconnect it. This hasn't improved things either. Nothing has changed. Everything is in the same location as it was before. Help!
Re: Doorbell device loses WiFi connection
@M4R5H Have a look at the ring doorbell app, device health and the signal strength RSSI value, if in the high sixties then a signal problem.
Understanding wifi recommendations for Ring devices
Avatar for M4R5H
It's showing 51 when I reconnect which is fine. But then showing 71 when it's disconnected. I'm unsure what the difference is between both times?
@M4R5H It's losing the wi-fi signal to the doorbell, i had similar, fitted a powerline wi-fi adapter down next to the doorbell, had to get through a tripple glazed door, then a solid wood glazed door to the nearest wi-fi AP point that i had, lucky had a power socket between the two doors, now reading is 30's and no more problems with the ring ever!
