Discussion topic: Does the wifi max hub have qos built in?
This message was authored by Jjwilsonx This message was authored by: Jjwilsonx
So im tempted to upgrade my router to the wifi max hub. Im currently on the full fibre 100 package.
i have a few questions, does this router allow you to change the QOS settings in the hub and is this a better upgrade from my old hub the black model for a ethernet connection.
Re: Does the wifi max hub have qos built in?
@Jjwilsonx  There is no QoS settings on any of the Sky routers. Which black router do you have just now and how many ethernet ports does it have.
@Jjwilsonx
It doesn't have QoS as such but has cloud based optimisation (or something like that)
Don't just get it because you think its the be all and end all
Jjwilsonx
I have the SR203 model,
I just noticed it has a lot a of bufferbloat on the upload side of things, reaching nearly 250ms but on the download it's a steady 20, so was thinking of either upgrading the router or buying a 3rd party possibley
