Discussion topic: Does sky have a router/hub with more than 4 ethernet ports
This message was authored by: DS2003
I have 4 ethernet ports on the rear of the router, does sky have a unit with more than 4 ethernet ports....
Re: Does sky have a router/hub with more than 4 ethernet ports
No, most if not all ISP provided hubs are 4 ports.  You could invest in a  relatively inexpensive gigabit switch if you need more ports.
Altenatively a decent 3rd party router can have more ports.
@DS2003 buy yourself a cheap unmanaged gigabit ethernet switch you can get them with 5 ports for under £10.  When picking the size you need that one port is required to link to the hub. Netgear and TP-Link are reliable brands,.
