Discussion topic: Does broadband hub have a separate return address from other equipment?
This message was authored by: Puzzlepot
Which address  do I  use to return broadband hub?
Re: Does broadband hub have a separate return address from other equipment?
Hi @Puzzlepot
See the following link for all Sky returns information.
https://www.sky.com/help/articles/return-tv-broadband.
If necessary you can use you own Packaging and also print your own labels.
Ensure that you keep proof of posting as the Sky return system handled by Unipart has delays and is not as reliable as would be desired.
