07 Feb 2025 04:13 PM
Brought a secondhand hub from eBay connected up ok but when I go on sky app it doesn't recognise hub how do I update hub without the phone call!
thanks
07 Feb 2025 04:35 PM - last edited: 07 Feb 2025 04:42 PM
Which Hub model have you bought?
Sky Broadband Hubs and Max Hubs are loaned to Sky subscribers and so shouldn't be available second hand. Q Hubs are becoming obsolete, and so not a wise investment.
07 Feb 2025 04:36 PM
It's the white WiFi max hub
07 Feb 2025 04:37 PM - last edited: 07 Feb 2025 05:05 PM
Those only function as designed when ordered directly from Sky: you'll never see the settings appear in the My Sky app otherwise.
I'm afraid you'll need to arrange a return to the vendor or raise a dispute with eBay: a Max Hub just shouldn't be on sale.
07 Feb 2025 04:39 PM
Ok thanks!
07 Feb 2025 04:50 PM
You may actually be better off. If the Hub doesn't get associated with your account then hopefully it won't get locked down either. So you can maybe access & manage ye olde way through a web browser.
09 Feb 2025 08:23 AM
Yes your probably right! It's working ok to be fair it's just that I noticed it's not showing as connected on app.
thanks
06 Mar 2025 10:31 PM
Hi, is this still working as expected? I have one on the way and not sure what to expect?
07 Mar 2025 06:15 AM
Yes working fine
07 Mar 2025 02:02 PM
Thank you. Was it just plug and play and connect to the new SSID?
I take it can access settings via 192.168.0.1 as normal if needed just no settings via my sky? (Dont have them on current router so hopefully wont miss this feature)
Thanks again
07 Mar 2025 02:11 PM
May be better to change the SSID & password to match the old router, then everything should just reconnect.
07 Mar 2025 03:31 PM
plug and play and yes just setting through the router like you said not on my sky!
