Discussion topic: Do i need to change my sky hub ( router ) by the 31 Dec 2025 as it will lose its service and securit
Message posted on 16 Jul 2025 10:13 AM
sky sent me a E-MAIL in February 2025 saying it will discontinue the service and security for my present hub ( router ) on 31 Dec 2025 is this correct or not.
Message posted on 16 Jul 2025 10:20 AM
Re: Do i need to change my sky hub ( router ) by the 31 Dec 2025 as it will lose its service and sec
You can continue to use it but it will no longer recieve any security updates after then so it is advisable to order the free replacement via this link:
sky.com/skyhuboptions
Message posted on 16 Jul 2025 12:21 PM
Hi @Bob161
It is indeed correct if you have one of the older Sky hubs. I would recommend you upgrade sooner rather than later, this should be a free replacement from Sky.
