Discussion topic: Do I need an DSL router to replace Sky hub
This message was authored by: TheMillkman
Hi,
Do I need to buy a router with DSL to replace the sky hub?
I'm looking at the As us aX82u
DSL: https://www.laptopsdirect.co.uk/asus-dsl-ax82u-dual-band-2.4-5ghz-5400mbps-wireless-router-90ig05q0-...
Re: Do I need an DSL router to replace Sky hub
@TheMillkman
That will work for a superfast vdsl connection.
Could you post your hub stats to make sure
Avatar for TheMillkman
I haven't got stats at the moment, but it's 500mb fibre.
I can try to get the stats.
@TheMillkman
Then you are on full fibre and the ont is the modem. You will need to look at the asus rt ax82u instead of the dsl model
Thats the answer I need. Thank you
