Discussion topic: Do I have the latest Sky Hub?
This message was authored by Billy+McKnight This message was authored by: Billy+McKnight
20240331_212006.jpgDo I have the latest Sky Hub for my Sky Broadband Superfast?
Re: Do I have the latest Sky Hub?
@Billy+McKnight
It is still the standard hub for superfast broadband where the phone is plugged into the mastersocket unless you upgrade to broadband boost in which case you get the sr203.  You also get the sr203 as standard with fttp and when your superfast line has internet calls.  It should be redundant at the end of 2025
@Billy+McKnight
That's the Q Hub from 2016
Since then, Sky has released the Broadband Hub (2019) and Max Hub (2023) both of which typically require payment of a subscription supplement.
As @cookiemonsteruk indicates, the Q Hub becomes obsolete with the switch-off of PSTN at the end of next year.
