8
This discussion topic has been answered Discussion topic: Do I get seperate router for ground and first floor?
This message was authored by: srinivasj
Hi There.
I am thinking to take Sky Full Fibre 500 mb/s Broadband connection and I have a query please.
Do I get 2 seperate routers for ground and first floor or the hub that will be provided is strong enough to cater for all the rooms? Could someone please advise so I can go ahead and take the connection?
Currently I am with another provider where I got 2 eero routers for ground and first floor.
Many Thanks in advance.
Srinivas
This message was authored by: SKY1992bf Answer
Re: Do I get seperate router for ground and first floor?
@srinivasj  Sky will only supply one hub , should the singal not be strong enough you would need to purchase WiFi extenders to boost the single
Avatar for srinivasj
Many thanks for your swift response. Very much appreciated.
Any idea the router that will be provided will have strong signal to cover 2 floors?
Pls advise.
This message was authored by: Sayek
You can actually cover the whole house with a single decent router. I am currently with Virgin Media waiting Sky 500 to be installed on 29th April.
My TP-Link router covers all over the house including the rear extended kitchen. Its a 3 bed mid terrace solid wall downstairs but plaster walls upstairs.
Most ISP router are cheap junk just enough to meet minimum and will lead you to scream later if you depending on them for Wi-Fi.
Keep that Eero mesh system and use with Sky.
Many thanks for your response.
Please provide your feedback after 29th April so I can then decide.
Kind regards
SJ
Happy to feeback after a weeks use
Nope: you've got one router and one linked mesh node. Each Eero unit is equipped to act as a router, but only one will be doing so.
Hi Sayek.
Hope the switching went well and all is ok!
I shall wait till next week and pls let me know ur feedback
Many thanks
Hi Sayek.
Please could you provide your feedback?
Many Thanks
