30 Jul 2022 04:58 PM
Hi All
Any pointers as to how to disable DHCP on my SR203 router?
I go into Advanced -> LAN IP Setup and untick 'Use router as DHCP server' and apply - then the router reboots - and the setting is ticked again.
Any ideas?
Ta
Si
30 Jul 2022 05:03 PM
What browser are you using?
Sky hubs work best with non safari browsers preferrably via ethernet
30 Jul 2022 05:08 PM
@cookiemonsteruk Chrome via ethernet.
The router does reboot, it just doesn't disable the DHCP server.
31 Jul 2022 07:40 AM
Posted by a Superuser, not a Sky employee. Find out more@SimonDB try powering down the hub for 30mseconds as that can clear silly faults. The web interface is pretty clunky and may need that before making the change.
