26 Aug 2022 12:22 PM
I set up my new sky router today as I have changed sky contracts. I used tohave the old lay flat router and have been sent a stand up one.
In the past I have had no issues connecting devices to the broadband but as of today my sonos speaker and my ring doorbell are completly refusing to connect to the router. I have seen other articles on here regarding splitting the 2.4GHz and 5GHz into separate networks but this doesn't seem to have worked either.
Is there a maor difference between the lay flat and stand up routers that is causing the issue? In which case should I return everything to my previous router or is there something else I can do because I am completely at a loss?
26 Aug 2022 12:28 PM
Posted by a Superuser, not a Sky employee. Find out more@DaniP1987Have you been asked to return the old router back to Sky?
26 Aug 2022 12:30 PM
I don't believe so. Need to return old Sky Q boxes but I don't think I was asked for the router.
26 Aug 2022 12:32 PM
Posted by a Superuser, not a Sky employee. Find out more@DaniP1987Would go back to using the old router for the time being. If you can change the Wi-Fi name to the same as the old router and then if you are asked to return the router it gives you a chance to troubleshoot issues.
26 Aug 2022 12:37 PM
@DaniP1987 wrote:I set up my new sky router today as I have changed sky contracts. I used tohave the old lay flat router and have been sent a stand up one.
Unless you have 'internet call' where your 'phone handset connects to the Sky Hub, you could swap back to the Sky Q Hub
