Discussion topic: Devices connected to booster
Message posted on 11 Aug 2024 08:26 PM
I have sky giga fibre that works great, though when both me and my girlfriend are working from home my office in the furthest end of the house suffers a bit.
ive got a booster to assist with this but once its on every device in the house connects through the booster rather than router, ultimately slowing everything down as it'll only allow up to 250mbps.
is there a way to choose which devices connect via the booster? I thought it was automatically off of the best signal, but when my mobile/games console and sky glass are connecting to the booster when I'm in the same room as the router it doesn't make sense.
Message posted on 12 Aug 2024 07:34 AM
Re: Devices connected to booster
@Twbr96 Devices will always connect to the strongest wifi signal which if they are physically closer to the booster will be that unit which will often be slower if its a "booster". A booster operates as a relay which can only deliver 50% of its connection bandwidth to the router - the other half is used for the backhaul traffic between the booster and the router.
If you really require higher speeds than 250Mb/s, which in practice is highly unlikely for 95% of business and leisure apps, then you need to change the booster for a mesh network solution ideally a triband system thst uses a third signal for backhaul activity. Sky's WiFi Max bundle is a triband system when the extenders Sky provide are in use but the extenders themselves are WiFi 5 devices so top out around 600Mb/s. You can buy multiple thitd party whole home wifi mesh systems if you prefer.
As pointed out above before spending money consider what if any apps beyond speedtests are impacted by your current speeds as few apps can use 100Mb/s let alone need higher speeds.
Message posted on 12 Aug 2024 07:42 AM
Appreciate the response Chrisee,
that's exactly how I thought it worked, which is why I'm confused by the devices close to the booster running at around 480-550 mbps are then choosing to connect to the booster that's at the other end of the house when it's turned on.
the moment it is on every device in the house switches to it that brings the speed up for those in close proximity but slows everything else down like the sky glass and mobile devices.
Message posted on 08 Sep 2025 05:49 PM
Did you ever get a fix for this? I'm having the same issue
Message posted on 08 Sep 2025 06:04 PM
Sadly not, an engineer visited and stated that all devices will continue to connect to the booster so my speeds are better by just not having it on at all!
so the solution was to just not have a booster.
Message posted on 08 Sep 2025 06:05 PM
so the solution was to just not have a booster plugged in at all.
