Discussion topic: Date when Sky Hub 4.2 goes live
This message was authored by: NevH
Just received the new Sky hub 4.2.  The instructiions I received said that I must wait until after installation date on the Hub box before starting the installation.  Does anyone know where this date will be as I cannot find a date anwhere on the boxes I received or on the Hub itself.
Re: Date when Sky Hub 4.2 goes live
@NevH
If that's a replacement for a Q Hub, you can swap it over whenever you want.
This message was authored by: Weyes
I can't find date either. Did it work if you have installed it ?
@Weyes if its a peplacement hub just swap with the old hub and it should work.
