Discussion topic: DNS lookup for a site not working
This message was authored by: Debaser
Any reason when I try and use a work website hosted in Azure (......hcp.northeurope.azmk8s.io), it only works if I manually change my work laptop DNS to use 8.8.8.8 (google) or 1.00.1 (cloudflare)
Anybody know how to get this fixed?
Re: DNS lookup for a site not working
@Debaser
When was the site setup/changed? It could be that the DNS entry for it hasnt propagated to Sky's DNS servers yet.
I am NOT a Sky Employee
Avatar for Debaser
I just looked up the TTL (Time to live via the DIG command) and it looks to be just 60 seconds. But good shout...
Anything else I can check?
@Debaser
Check Sky Shield is disabled for your connection
Avatar for Debaser
@jamesn123 I did check, and it looked to be already disabled. I have been busy at work, so just configured cloudflare DNS for the last couple of weeks. Anything else you think I could check
