13 Jul 2023 02:17 PM
13 Jul 2023 02:21 PM
Can you post your hub stats
13 Jul 2023 03:10 PM
System Up Time: 43:34:26
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time
WAN MER 24003 170707 0 13165 26145 00:01:51
LAN Up 887819 136480 0 17363 4352 43:34:26
WLAN (2.4 GHz) Up 34826191 9111059 0 39900 21812 43:33:11
WLAN (5 GHz) Up 13370841 6390491 0 0 43733 43:32:34
Broadband Link Downstream Upstream
Connection Speed 75349 kbps 20000 kbps
Line Attenuation D1(7.9 dB) , D2(17.2 dB) , D3(27.3 dB) U0(4.9 dB) , U1(15.0 dB) , U2(22.0 dB)
Noise Margin 3.3 dB 9.3 dB
That look OK? Not able to keep the formatting
13 Jul 2023 03:47 PM
Posted by a Superuser, not a Sky employee. Find out moreYour stats show the WAN has been dropping and you'll likely need an engineer to come out to look at the line.
Assuming you are connected to the master telephone socket in your home?
13 Jul 2023 04:12 PM
Yes. As neighbours have had the same will a Sky engineer still look into this? Or just refer it to OpenReach? (Also - what from those stats tells you that?
13 Jul 2023 04:20 PM
Posted by a Superuser, not a Sky employee. Find out moreIts down to Sky's discretion who they send first, usually its a Sky engineer, then Openreach.
The WAN uptime is only 00:01:51 whereas the router uptime is 43:34:26 so the WAN has dropped since the last router reboot
29 Jul 2023 10:44 AM
Have same issues broadband and phone dropping out regularly. Have had sky engineer out and openreach. Sky engineer say it is an Openreach issue, openreach say there is no issue. Can't work from home or use fitness equipment with WiFi programmes. Any suggestions? Sky Superfast 40 broadband running at 20 Mbs! Confirmed by Sky.
