10
This discussion topic has been answered Discussion topic: Continuing adsl disconnects and reconnects
This message was authored by: DaFugly
Broadband = Sky Broadband Unlimited
Router = ER115
Been having continuing disconnects and reconnects.
Have disconnected and reconnected all cabling and reset router.
Ran online tests - all report as good.
Phoned sky broadband support and was advised no faults found.
Any ideas would be much appreciated
This message was authored by: cookiemonsteruk Answer
Re: Continuing adsl disconnects and reconnects
@DaFugly
Well thats at least good newr re wbc fttp  There's no incentive for isp's to fix it as adsl2+ carries no guarantee and fttp is normally 10× more reliable than adsl.  Your noise margin is 0 db which means a bird on the wire would cause errors to get thru without any safeguards of a 3 db line
@DaFugly
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
@DaFugly Also time to look at the free hub swapout if you have not already been notified.
www.sky.com/skyhuboptions
Avatar for DaFugly
@caesarome
As per post, all suggested steps previously completed (sky operator even offered to upgrade to FTP lol).
I know my stable router statistics normally show Connection Speed of 23999/1117, Line Attenuation of 16/11 and Noise Margin of 6/7.
The connection has now been stable for over 2 hours and numers read as per originally posted "screen capture"
Looks like "suck it and see" for the time being.
Many Thanks anyway...
@DaFugly
Could you enter your full address below and post the table and notes after removing your address from the image
Avatar for DaFugly
@JimM1
Yup. have had email from sky re hub swapout.
I changed the router admin pwd on original install and will in the near future be upgrading to FTP in the near future.
Many Thanks
Avatar for DaFugly
@cookiemonsteruk
as requested:-
@DaFugly
Avatar for DaFugly
@cookiemonsteruk
Begs the question as to why i would suddenly have 0.0 downstream Noise Margin?
@DaFugly
A cynic might say that that the isp trying to artificially make you speed faster so you don't fall below you guaranteed speed
However adsl doesn't carry a guarantee apart from the universal service obligation of 10Mbps,  the max speed gained by an adsl connection with 3db would be 24Mbps so all that caper wouldn't be worth the effort
More likely dodgy modem or a weird fault that lowers your noise margins instead of increasing them for stabilty.  Anyways since your current hub is obsolete from december just see how the new hub goes.  Unless you go for 1 Gbps fttp the new sr203 will be the one you get for full fibre and even then the sky max hub appear low in stock so you'd probably get that for gigabit .  At least you have the safety net of 40,80,100,150,300,500 Mbps or 1 Gbps
Avatar for DaFugly
All mysteriously stabilised onernight.
Next step - will upgrade to FTTP.
Thanks for the assistance.
