27 Nov 2022 12:42 AM
For the past year or so the upload speed has dropped drastically to roughly around 0.45-0.70 mbps and I understand that sky do not guarantee a minimum upload but it hasn't always been like this. Numerous openreach engineers have been out and tested the router on their own and they get around 40 mbps down and 6-7 up which is what I should be getting, but what I'm not understanding about this is every time they finish and leave the speeds remain at around 35-40 mbps for down and 6-7 up which is brilliant but it only lasts for a couple of days before dropping again and remaining at around 20 mbps for down and as mentioned 0.45-0.70 for up and I test regularly using ookla on a pc which is connected through Ethernet. Any help would be greatly appreciated thank you.
27 Nov 2022 07:39 AM
Posted by a Superuser, not a Sky employee. Find out more@Tracey6519 first check that your hub is connected to your master phone socket using a line filter unless its the prefiltered type with a rj11 connecter for the hub to plug into.
Secondly can you post your hub's connection stats please see Find your Sky Broadband router statistics
27 Nov 2022 01:45 PM
Hi, thank you for the quick response. I'm pretty sure the router is connected via a master socket 5C.
and the stats are here:
27 Nov 2022 01:49 PM
Can you "run tests" from your my sky app or sky.com account and post the info in "more about your connection"
27 Nov 2022 02:01 PM
sure, the results are as follows:
27 Nov 2022 02:07 PM
"Guaranteed Minimum Download Speed: 30 Megabits per second"
Upload may not be guaranteed but download is.
Hopefully by addressing your download they will fix your abysmal upload as well
Call sky on 150 from your sky landline or
zero three three three seven five nine one zero one eight from any other phone
Or if in Ireland
Call sky ireland on
08.185.00.27.3
Remove all the full stops
To report the fault
27 Nov 2022 02:18 PM
yeah, well as you can tell the download isnt really the issue but the upload definitely is. with the amount of openreach engineers that have been out and tried to fix the issue the speed just goes back to this no matter what. im just really confused, though i will call them again and tell them what has been happening i just hope this gets sorted out sooner rather than later.
