Discussion topic: Constant freezing of sky TV, apps
Message posted on 08 Oct 2025 01:06 AM
Message posted on 08 Oct 2025 06:26 AM
Re: Constant freezing of sky TV, apps
@Adamhynd you are not addressing Sky by posting in the forum forum members are customers like yourself. Unless there is a fault with the broadband to your hub which the service checker innthe My Sky app will show the problem is likely to be poor wifi signal in your home.
To stream video or to play games you need a good connection from the hub to the device you are using. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
