Discussion topic: Constant connection drops Sky Max router via ethernet
Message posted on 04 Dec 2024 11:07 AM
Recently moved from BT to Sky via a fibre connection. Experiencing lots of connection drops on both WiFi and Ethernet connected devices, despite broadband/wifi checker saying all ok. Have followed some of the guidance from other posts (ie changed to WPA-2, turned off shield, etc). Still drops connection or regularly puts my calls on hold.
WiFi cover seems poor upstairs too, don't have this issue before (not massive house).
Any help much appreciated.
Message posted on 04 Dec 2024 01:32 PM - last edited: 04 Dec 2024 01:32 PM
Re: Constant connection drops Sky Max router via ethernet
Hi @Aj7405
Is the setup the same as your BT one? Router in the same location, boosters if you had them before
Which Sky hub do you have?
Message posted on 04 Dec 2024 02:00 PM
Hi,
Set up all the same as before, never needed boosters in past.
Had the black router when moved over in October, had same issues so upgraded to Sky Max thinking it would sort issue ... now have the Sky Max white router and nothings changed.
Message posted on 04 Dec 2024 04:15 PM - last edited: 04 Dec 2024 04:16 PM
@Aj7405 wrote:Hi,
Went live yesterday ( moved from bt) and WiFi was a bit up and down well below 500mb/s. Today i moved my sky max hub (full fibre 500) into living room via 22m cat6 cable from ont and pc, tv, sky q all connected by ethernet (cat6) from hub and its been rock solid with speeds to pc over 600.
Albeit its still new and different setup to your house but just letting you know how I've set mine up.
Sky Q 1TB UHD
LG TV
Sky Mobile
