Discussion topic: Connectivity from router to sky qbox
This message was authored by: Selly
Message posted on 17 Nov 2025 01:18 PM
The network connection within the settings section has an x by it. When I go to network set up it tells me to hold the button on the side of the router. After about 3 minutes it says connection failed.
Without the Internet connection I can't access BBC iplayer, YouTube etc. Similarly I can't connect to the mini box in the other room and get sky multiroom
Message posted on 17 Nov 2025 01:51 PM
Re: Connectivity from router to sky qbox
@Selly Switch it all off for a couple hours both the sky Hub and the sky Q box, see how it goes when you put it back on!
