Discussion topic: Connection Issues after upgrading to full fibre
Re: Connection Issues after upgrading to full fibre
@Alibongo54 And you speedtest.net with the 70.1/20.8 really shows you are working fine, and you may just have someone hogging all the upload bandwidth connection wise!
This message was authored by: Alibongo54
Thank you, I will do the ethernet test tmrw as waiting on a usb c to ethernet device as laptop does not have an ethernet port.
I don't have another router as I was with Virgin before.
Thank you for your responses though.
Just seen i put hive router!! Im using Sky max hub router
